Is that for the 65"?
Yes - the 65"
I have updated my post to show the size. Thanks
Great price thenYes - the 65"
That’s great!Finaly,yestrday i was able to buy Asus rtx TUF 3080 OC.
One month ago i buy 48gbps hdmi cable so last night i connect my pc to q90r.
Now i have option to play games in 4k/120hz/4:2:0/10bit/hdr
I will try it later.That’s great!
But what about VRR/Gsync? Does it work?
LOL i tried to put 12bit and now i cant enable deep colors on hdmi port 4,if i try i only get black screen......
Now i need to find solution for this sh.t
I just wanted to try it out...and now i have hell....i cant use deep colors on port 44k 120hz 12bits color? Tv does not support that
That was the first thing i tried,then reboot of tv and theen reinstal of gpu drivers.disconnect the cable and reconnect it, maybe it works, it did when the xbox didn't recognize the TV as 4k
Fixed now...kinda...but there is still some small issue that tv is changing picture mode by itself...dont know.
I agree.anyway a firmware update is likely to be needed for everything to work well, as the LGs have needed
Is getting a 4k player which has hdr10+ support a big difference from using my xbox one s with hdr10?
PANASONIC DP-UB159EB 4K Ultra HD Blu-ray & DVD Player
Works with Amazon Alexa & Google Assistant; Plays 4K Blu-ray discs / DVDs; HDR: HDR10+ / HDR10 / Hybrid Log-Gamma (HLG); Supports Dolby Atmos / DTS:X / High-Resolution Audio; Ethernet; 4K pass-through; USB playbackwww.currys.co.uk
Looking at this one but only if its worth the upgrade, after reading some stuff it does feel that Dolby Vision is becoming more and more popular while hdr10+ seems to be fading away.
I have not noticed to be honest, it looks ok to me but it could be crushing. I seen a bit ago about confusion as to what to have black level set too on tv while using xbox, when i put it on auto it looks ok, when i change it to limited or full (csnt remember which one) the image goes really grey so i assume that is in correct so i just leave it at auto. On ps4 it is essier as you have options on the ps4 and tv but you can't change the black level on xboxI also use the xbox one s as a player.
Did you correct the crushed blacks?
Because watching the same original movie in uhd on the xbox and a remux on the TV player, or plex, the difference in shadow detail is really big
I also have Q90R and Founders Edition 3080 and when using on HDMI Port 4 it doesn't seem to play nice. What should be the maximum we are able to achieve using this setup in terms of resolution, refresh rate and bit depth and with or without HDR? and G-sync/FreeSync?
When I connect my PC to my OLED65C9PLA in the living room using the latest available 5.00.03 firmware from LG I am able to set 3840x2160 @ 120Hz at up to 12bit RGB, HDR and with FreeSync/G-Sync!
Also another thing I noticed, the available audio formats when using the LG are huge when compared to what's available when using the Samsung?
Unfortunately Q90R is not officially a hdmi 2.1 equipped TV whereas you OLED is. However Q90R Hdmi port 4 does go beyond hdmi 2.0b and according to emanual supports 3840x2160 @120hz 10bit but only if you select chroma 4:2:0 rather than RGB. If that works you could try 10bit chroma 4:2:2 but officially that's not supported. Let us know how you get on.
Just to add to this, I think the TV needs a firmware update to play nicely with 4K 120hz. The OLED's from LG required a update too.
There is no option for 4k/120/4:2:2 only 4:2:0.Unfortunately Q90R is not officially a hdmi 2.1 equipped TV whereas you OLED is. However Q90R Hdmi port 4 does go beyond hdmi 2.0b and according to emanual supports 3840x2160 @120hz 10bit but only if you select chroma 4:2:0 rather than RGB. If that works you could try 10bit chroma 4:2:2 but officially that's not supported. Let us know how you get on.
I played yestrday Forza Horizon 4 in 4k/120fps all ultra with hdr....experience is fantastic BUT things with this kind of signal gets fast buged and i get no source signal black screen.
So thing is....it works but it needs to be improved by Samsung i think.
