mstar
Established Member
- Joined
- Mar 29, 2008
- Messages
- 196
- Reaction score
- 9
- Points
- 65
Hello all.
I am planning in my main room to have my samsung UE55ks7000 wall mounted with sky q in the other room. I am going to hide the cables to the mains socket using brush plates behind the tv and below next to the double power socket. I will also feed a ethernet cable to the TV from the brush plate to the wall mounted tv.
My dilemma is:
1. How do i hide the Samsung one connect box? do most of you attach it behind the TV or use a little AV shelf underneath? any recommended solutions?
2. I am running a 10-13 metre HDMI cable from the sky q box to my wall mount tv. Is this ok or my signal will diminish with this long reach?
My dilemma is:
