thanks for the help. another question? how do I do the backup, my main board is dead..or do you refers to the new board?you need similar board which fit with holes and connectors, then you need to adjust few things in service menu and should work.
But first you need to backup all settings from service menu.
check on ebay for spare parts.
"Easy backup" would be if your board was working, by taking some pictures from service menu which is not your case right now.thanks for the help. another question? how do I do the backup, my main board is dead..or do you refers to the new board?
my hero...tks"Easy backup" would be if your board was working, by taking some pictures from service menu which is not your case right now.
Then you need to look for similar board on eBay and you can also search for service manual and then adjust settings according to SM
My old TV H6640 is still on firmware 2115.3 with oscam and Sambilight running. This new firmware do not bring any new features.Surprised to get notification of a new firmware available, popup on my 48" model last night. Anyone else seeing this? FW version 2910
