nickdc
Established Member
I'm hoping to connect the Zone2 audio output (standard rca ports) of an Arcam SR-250 to the power amp input (standard rca ports) of an Arcam A90 in a room at the other end of the house. The cable will have to be routed along the outside back wall of the house and I estimate the length of cable needed will be about 15m. I'd be grateful for advice on all or any of the following:
1. Is this a feasible project - a run that long and mainly exterior?
2. I assume the cheapest option would be to make up the cable myself, but I have limited experience and wonder if the extra cost of having the cable made professionally is worth it.
3. Recommendations for the type, brand or specs of cable I should use, trying to reasonably balance cost and quality.
4. Recommendations for the type, brand or specs of rca plugs I should use. (Assuming I make them up myself.)
5. Links or comments to help me make a good job of such a project.
