E Emmanuel 1965 Novice Member Joined Jun 23, 2020 Messages 2 Reaction score 0 Points 1 Age 58 Location London UK Jun 23, 2020 #1 Place the smartphone face up on a translucent or transparent box lid. Then use your voice to turn the smartphone torch on and off.
1742 Distinguished Member Joined Oct 4, 2008 Messages 4,263 Reaction score 6,921 Points 1,916 Jun 23, 2020 #2 That would be a good way to drain your battery on your phone. Maybe just buy a night light?
BM08 Prominent Member Joined Jun 24, 2012 Messages 1,876 Reaction score 590 Points 389 Location Worcestershire, UK Jun 28, 2020 #3 Yeah not really a viable option, especially if you’re using it for 1/2 hours, and if it’s you’re only phone you can’t use it while it’s being used as a light
E Emmanuel 1965 Novice Member Joined Jun 23, 2020 Messages 2 Reaction score 0 Points 1 Age 58 Location London UK Nov 10, 2020 #4 If you are charging your smartphone at night then you won’t draining the battery. Also my iPhone 7 operates normally with the torch on.
