Some pictures of your recent purchases
aVdub
To make my life much easier.
If anyone can suggest decent (I'm not bothered about waving a brand name around and shouting how much it cost) foam insert that I can cut and insert my electrical tools, I would be very grateful.
Pretty quick turn around from ordering to delivery, with the base being out of stock after being ordered, but I suspect it came direct from Germany.
Davekale86
Be interested to see any footage or still shots at daytime and esp night from this.
What's it like if you are standing a few feet in front of it at night looking into camera if your face (or mask if you prefer) ;)
Is visible, or blown out due to IR, or IR not needed due to floodlight.
Looks an interesting product.
Will be installing it this weekend so when it's done I'll give my thoughts
jouster
Some more bike bits - a phone mount View attachment 1311183
As someone who ride with a phone mounted on stem for quite sometime, do bare in mind that if you ever come off for whatever reason, there is a chance your phone will come off badly.
Yes it’s really convenient having it there but in truth it’s just adding to the risk of it getting damaged. Just something to bear in mind
Doug the D
Ok, well, arrived nice and early, not as BIG a drum as I'd feared, but sheesh it's a heavy lump to even roll.
1st job I think will be to cut in half.
I think a plan is, put car in road, park front wheel on end of cable, roll spool down the road, and either measure (but I think road is not long enough) or put both ends under car tire fold in half, if you know what I mean!
I'm not sure what cable that is mate, but if at all possible, see if you can run the cable out this way instead; get a metal bar and put it through the drum. Elevate both sides of bar to lift the drum off the ground. Pull cable off and cut to length required.
If you do it the way you've described, you'll find it's more difficult. I've been running out or rolling in cables for most of my life for some reason or another, I am well versed in the art!
Tempest
It's official I'm an idiot!
I had all my cable rolled out, and needed 4 sections (two lots of two lengths)
I cut the 1st section, then decided how best to cut the next section (two lengths the same)
Dragged them round the back, so now I just had to cut the remaining about in half and job done.
I came back round the front, and saw I had 2 pieces, not one. WTF!
Brain goes into meltdown, how did I do that, I don't know and I still can't work it out.
I had ONE length, cut an amount off this length, which means I had 2 bits (one I wanted and the long rest of it)
I then cut a second amount off the long length to get another of the bits I wanted.
Took that round the back and then I have 2 bits on the front lawn. This does not make sence, and I can't work it out.
So I had one longer than I wanted bit, and one shorter than I wanted bit left.
how just how?
So now I've got to order some more, DAMMIT.
Tempest
Ohhhh, I know what I did.............
116 meters and I wanted:
2off 36m
2off 22m
I measured it, when arrived to check I had the right amount as did not want to end up with a short bit.
I'd ordered 114, but got 116 :)
So 1st thing was to cut the whole length in half so I had 2 equal lengths.
Then I just needed to cut 22m of each of these lengths and I'd have all 4 bits I wanted.
So, cut them in half = two 56m lenghts.
I cut 22m off one of the 56m lenghts. (so far so good)
Then rather than cut the other 22m from the other 56m length, I cut the second 22m length of the same 56m length....
DAMMIT.
So I was left with one 56m length, and one 12m length.
What a cock!
Phil1975
Some linen trousers and shorts..just delivered when the weather has done a complete 180..!
:facepalm::D
shahedz
As someone who ride with a phone mounted on stem for quite sometime, do numbers in mind that if you ever come off for whatever reason, there is a chance your phone will come off badly.
I did consider a small garmin too but like the flexibility of apps on the phone. The phones insured - so if /when I drop hopefully one way or another It will be ok.
batfinkus
2off 36m
2off 22m
DAMMIT.
What a cock!
I’m interested in what sort of cable it is and what you need 56m lengths of it for?
the best outcome is that it’s for a massive catapult in the back garden:)
Dony
2off 36m
2off 22m
DAMMIT.
What a cock!
Half of 116 is 58, not 56.
Tempest
Just 4 runs of cable down the back garden, two to an area half way down-ish, the other runs to the bottom.
It's actually quite educational like any projects, things I thought about, like pulling cable round multiple bends... ha ha, not a hope. I've had to dig out all angles and even then it's hard to get 4mm armored around bends.
Hands on learning :)
Good fun in a frustrating kinda way, it's just amazing how much time simple things take without prior knowledge/experience/tools.
Yeah jist a mispulling ;)
Tempest
Ditch the karcher one and invest in an auto brite snow foam lance. I use one on my k2 and i get lovely thick foam.
Be honest with us here......
Was this you that did this?
imightbewrong
Finally
(for those from the other thread, this is the replacement)
pRot3us
Anyway back to the purchases, today's arrival, just in time for tomorrow's watching of Jaws 4K :cool:
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
Trending threads
Latest News
Philips online events to replace IFA 2020 attendance
  • By Andy Bassett
  • Published
Marantz announces 8K ready SR series AV Receivers
  • By Andy Bassett
  • Published
Ennio Morricone: Legendary film composer dies aged 91
  • By Andy Bassett
  • Published
AVForums Podcast: 5th July 2020
  • By Phil Hinton
  • Published
Sky comedy panel shows back to film new series
  • By Andy Bassett
  • Published
