GarethP
Hopefully getting there. My phone is doing the random rotate thing... so I’m editing the image
Hhhmmm, what's your definition of silly money. I still have my psp with cfw and I'd be happy to flog it but looking on ebay we're talking about £50 or so.If the screen isn't yellow, it's easy to sell with CFW on eBay and get silly money considering. I'd keep it for PSX classics; Vita can look a bit fuzzy due to higher resolution screen.
10 degrees is a t-shirt and shorts for running! 9 degrees is a long sleeve top.
But then I'm probably carrying more "insulation" than you.
oh this isnt for running..this is for popping out and about in the autumn I was only wearing a long sleeve compression top back in FebruaryWould not be able to wear that while running.
Struggled earlier in the year trying to run in a hoodie over my vest after spending 2 years running in just shorts and vest regardless of the temp.
Weber wanted how much? I have the same thing made by Vonshef, I use it for burgers also.Griddle for the bbq so I can do smash burgers. £15 instead of the £80 that Weber wanted.
i used mine after shearing off my MTB stem bolt....unfortunately it didn't work for me but that bolt was soft as butterBought this, didn't use it for two years. Was a god send a few weeks ago when I sheared the top a bolt off!
Oh I've seen them go for more depends what apps have on there and memory card size!Hhhmmm, what's your definition of silly money. I still have my psp with cfw and I'd be happy to flog it but looking on ebay we're talking about £50 or so.
Oh, right. More research required then. Cheers.Oh I've seen them go for more depends what apps have on there and memory card size!
Its in really good condition, but don't think I could sell it tbh. Had it from launch, like the PS1 PS2 PS3 2003 slim & the PS Go.If the screen isn't yellow, it's easy to sell with CFW on eBay and get silly money considering. I'd keep it for PSX classics; Vita can look a bit fuzzy due to higher resolution screen.
Care to share your diet plan? Perhaps not in this thread though. Please don't tell me you gave up alcohol..I have very little in the way of built-in insulation anymore if honest...+ and - of being fitter I guess...13-14% bodyfat has put pay to that
To be fair Weber's covered half my cooking space, swapping out one side of the grill for a massive piece of iron. But I don't have £80 to blow on a griddle and also don't want to lose that much cooking space for other stuff.Weber wanted how much? I have the same thing made by Vonshef, I use it for burgers also.
You don't need a recipe. Just 10% - 20% fat mince, and make it into balls before you cook. Don't overwork the meat. I'm only parroting what I've watched on youtube but making a ball smaller than a tennis ball seems about right, and throw it from hand to hand a bit. I made normal burgers like this the other day and they didn't fall apart, so it seems you only need egg when you're adding all the other stuff, like onion, breadcrumbs, herbs etc. Season the patty just before the smash, otherwise the salt will extract the moisture.I see a lot of 'smashburger' pictures on reddit. They look kind of insane - do you have a recipe link?
I have a griddle pan for our Weber although it has small holes.
I kept seeing adverts for this on Facebook and then last week I had to dremel a slot into a sheared screw to get it out. This set was cheap, it’s in a tiny box, so it’s been thrown into the toolbox to prove it’s worth in a few years time.
Technivorm Moccamaster for £25
If it's the 1000 series you have I have a couple of these coming from AliExpress (should be here in a week or two) which I no longer need as I've moved to a 2000. I was going to chuck them on eBay but happy to start a thread on the classifieds if you're interested.
Nice . I have one of these. 75 grams of coffee, fill up the water tank and turn it on. Could not be simpler. I have the one with the thermos flask, one brew lasts me all day.
Compress it for 45 seconds to seal it, and only flip once.
Like I say, this is from memory. I've not even smashed one yet! I'll stick a post in the bbq thread when I do.
I've been mincing Flat Iron, Denver and Bavette with good fazert content, which is always a nice and soft fat.
Throwing from wet hand to wet hand and also cupping slightly to form the shape
The compression is something I've not yet done, but like the sound and will give it a try soon.
As I've been mincing my own I have been using Flat Iron, Denver and Bavette steaks and select a few with good fat content, which is always a nice and soft fat.
Same with the throwing from wet hand to wet hand and also cupping slightly to form the shape as I do.
