I'm hoping the Arc will fit where my Playbar currently sits, on shelf about a foot below the TV (and you cannot tell where the sound is coming from, trust me).Speaking of height clearance...
Do/will any of you raise your TV and if so how?
I have made provision in case it doesn't work there, however, with a sheet of 30mm MDF that I'll cut in half, giving 6cm of lift to put the Arc in front of. I worked out that the TV will need to go up 5cm for the Arc but the extra 1 cm is because the TV is already a bit higher than I'd like it (no way round that) so it should compensate for the angle of view.
