makershaker
Established Member
Is it true if I buy a Sonos beam compact and connect it via ARC HDMI it wont switch off when you turn the TV off?
Yes correct. For some reason you command the tv to turn on but not off unless you select the hdmi input the beam is connected too and then for some strange reason you can command the tv to turn off! Weird!Is it true if I buy a Sonos beam compact and connect it via ARC HDMI it wont switch off when you turn the TV off?
