Morphyy
I have the XE93 which I purchased from Currys and was delivered/installated 14th of April. £3,199 including the Sony X800 UHD HDR - Blu Ray player (2017 new model). I was going to buy this X800 Blu Ray Player anyway so happy with the offer.
I saw the XE93 and XE90 side by side at a Sony center in March, playing same content and similar settings. Sony did not have the offer at the time so i decided to wait. It was obvious that the XE93 had the superior picture, very noticably much more detail and brighter.
So far from 50+ hours viewing I can share the following from using the TV Native Android Apps (NETFLIX, AMAZON VIDEO, BBC iPLAYER, YOUTUBE, VEVO, VIMEO).
CALIBRATION SETTINGS:
I USED THE TV CALIBRATION SETTINGS MOSTLY BASED ON THE XE90 AVFORUMS YOU TUBE REVIEW.
ALSO CHECKED THE CALIBRATION SETTINGS FROM FLAT PANEL TV:
Sony X93E (XE93) review - FlatpanelsHD
Four settings used:
(1) SDR Daytime settings in Cinema Home mode.
(2) HDR Daytime settings in Cinema Home mode.
(3) SDR Night settings in Cinema Pro mode.
(4) HDR Night settings in Cinema Home mode.
Pros
Cons
My ratings for this TV:
REFLECTION ISSUES
I EXPECTED THAT A TV OF THIS STANDARD WOULD BETTER HANDLE LIGHT REFLECTIONS. HOWEVER I AM NOT GOING TO RETURN IT AND WILL PURCHASE SOME LIGHT MINIMISING WINDOW NET CURTAINS.THERE WILL STILL BE REFLECTION IN A DARK ROOM BASED ON THE LIGHT FROM THE TV ITSELF.
Four settings used:
Pros
- Colours look very natural.
- Auto HDR mode TURNS ON automatically when ever there is HDR Content on NETFLIX & AMAZON VIDEO. No need to change picture settings.
- Bright pricture if you need it.
- No dead pixels as often the case by other sub qiuality control manufacturers.
- Good uniformity of picture.
- HDMI ARC works perfectly with my BOSE Soundbar.
- Good internal DAC for Headphone audio connection - much better than they need to be for a TV.
- Superb Build quality.
- Google Voice via remote is very responsive and accurate - about as good as Apple TV siri remote
- 1080p upscaling is impressive.
- 4k UHD content looks amazing and better than some HDR content.
Cons
- Too much reflection. Very very suprised that on the popular YouTube Review sites this abvious flaw has not been picked up or even mentioned. There is WAY to much reflection. WARNING - ONLY GET THIS TV IF YOU HAVE A VERY DARK VIEWING AREA, OR NIGHT TIME VIEWING. EVEN AT NIGHT THE LIGHT FROM THE TV INTO A DARK ROOM CAUSED REFLECTION. IT IS LIKE A MIRROR.
- Not as impressed with HDR content as people have promoted. Basically even at Night the HDR content from (Marco Polo on Netflix) & (Patriot on Amazon Prime) = too dark. Dark scenes are just too dark and also the TV reflection as in point 1 above, makes the problem worse. NETFLIX - Iron Fist (HDR) looks terrible you can see dots and is so bad.
- Glowing Blooming around white subtitles even with Extended Dynamic Range turned off.
- Very minor letter box issues with white hallowing - some times. Not a major issue to me.
- Contrast/Dynamic Range/Black Level (8 out of 10)
- Screen Uniformity (10 out of 10)
- Colour Accuracy (8 out of 10)
- Greyscale Accuracy (8 out of 10)
- Video Processing (7 out of 10)
- Picture Quality Out-Of-The-Box (6 out of 10)
- Picture Quality Calibrated (8 out of 10)
- Sound Quality (1 out of 10)
- Smart Features (5 out of 10)
- Build Quality (9 out of 10)
- Ease Of Use (5 out of 10)
- Value for Money (5 out of 10)
REFLECTION ISSUES
