Sony V Philips power usage
Mikeypascoe
Does anyone know where I could find how much power consumption my 30' sony bravia tv from 2010 uses ?
Im trying to compare it to a Philips 50' 6100 series I just bought.
Which one uses the most power ?
JayCee
Do a Google search using “Sony (insert full model number here) Specs” and you'll be able to see the power consumption listed or check the specs in the TV's user manual.
Mikeypascoe
Thanks JayCee I did a search but it said manual for 32v3100 unavailable on Sony website.
Is there an "energy" website that compares models power usage ?
JayCee
No, not that I'm aware of. It would need to be massive and include all brands, models and screen sizes.
I did a search for your KDL-32V3100 specs and/or user manual but couldn't find it either.
You'll probably find the power consumption printed on the label on the rear of the TV where the model no is.
LG CX 4K OLED TV Review: The best TV of 2020?
