releaseyourself
- Joined
- Feb 1, 2007
- Messages
- 87
- Reaction score
- 2
- Points
- 26
Looking for some advice...
I have a MJ Acoustics 50 MKII Active Sub that was working via my TV Sub RCA output.
It has since stopped working, i tried a new cable, power on and off, disconnect, reconnect and check tv sub settings. If i remove the RCA from the Sub, it makes a noise. Sub amp is lit up and i tried the high level which works.
Do you think it is the low level on theSub that is faulty?
