aliegilbert
Hi guys, hoping someone can give me a bit of an insight here.
**I am aware it was my fault, I'm silly and I'm just looking for guidance from my silly mistake**
I took part my switch to put a new shell on, second time. First time went totally smoothly and was way over a year ago. Last night I decided to put another on, I know, rookie mistake, I'm just impulsive.. - everything works, it also looks so cool may I add. The ONLY issue is, the right joycon won't pair with the switch anymore. I've disconnected all remotes, pressed the little button circle button to repair, taken it apart again and 'checked' the little ribbon cable.. nothing..
However it does still charge it... It just won't pair. Shows either that red bar when it clicks in or nothing..
What on earth did it do??
Have I damaged the cable or not connected it properly? I guess that's the only thing?
Thanks all and hope you are all keeping safe and well
Alexandra
Alexandra
