Waynester
Hi Folks
Got a new table TV stand yesterday off of Amazon, it’s to raise my TV up so I can fit my MA Bronze Centre Speaker underneath it and give me a better viewing angle and better sound, which it already has... trouble is the stand is on its highest lift setting, it’s just not high enough and my speaker is still obstructing the bottom of the TV and the IR Sensor for the Remote Control
My TV is a Panasonic TX-55CX802B, it uses VESA 400 x 400 size holes, it weighs 25kg in total
The trouble I’m having is that no stand anywhere lists the distance left between the bottom of the TV and the bottom of the actual TV stand, I need a minimum distance of 7” - 8” (18 - 20cm) to fit my MA Bronze underneath the TV
here’s some pics and you’ll see my issue
has anyone got a similar TV stand and a 55” TV or bigger and have at least this required distance or more left?
Driving me insane as I can’t keep ordering stands off of Amazon
I don’t want a floor stand type, only a table stand but there has to be one that goes a bit higher..
Other than that I’m very pleased with it
Here is my exact stand and the pictures of it setup
Wooden Base TV Stand - Universal Tabletop TV Stand for Most 32-55 inch Flat and Curved TVs with 8 Level Height Adjustable TV Base Stand and Cable Management - Max VESA 400x400mm Holds up to 45KG Amazon product ASIN B07Z98SM7T
