shahedz
- Joined
- Apr 26, 2005
- Messages
- 11,733
- Reaction score
- 2,654
- Points
- 2,364
Change the wheels.
what’s the fun in that !
Change the wheels.
Thought I’d post these pics here than reply on the purchases thread
really , really simple to use . My room is fairly curved and the suckers clamped onto it no problem. They are - not coming off.
really quick to put on and take off .View attachment 1349793View attachment 1349794View attachment 1349795View attachment 1349793View attachment 1349795
£129.99 much cheaper than the sea sucker alternative so very pleased .
It’s not airtight and maybe the sealant has now plugged the small gap, or it could be the valve has moved ever so slightly and upset the sealant and by you pumping it up again and moving the valve and it’s corrected it.Bought my scooter with “ pre inserted puncture sealant “ which didn’t work when I got a puncture ( 1 month ago ) as it just leaked out
So got some slime from Halfords and it fixed it instantly
Today some of the old slime ( not the stuff I put in ) was leaking out the side of the valve where you pump it up and I got a flat tyre
So before attempting to change the innertube I tried pumping the tyre up and it pumped up fine without any punctures
Any idea what happened ?
I guess that depends on your budget?I’m in a right old mare choosing some road glasses, either through actually choosing or stock availability.
Any recommendations?
The lens is about £80, so would make them even more expensive. I'll just wait for stock. Was just thinking about other brands to consider as well.I don't think the Flight Jackets are necessarily any bigger than the Jawbreakers, the lens now extends up to where the frame would have been and maybe makes them look bigger.
Could you not buy a pair in the frame color you want, then buy the jade lens separately?
There are a million action cams on amazon that will fulfill the purpose. I picked up a 4k Campark one for about £40. Kids loved using underwater on holiday.just saw this on offer for 26 quid..
do, you think it could be used as a cheap alternative to a go pro and strapped to me whilst riding?
