Clem_Dye
- Joined
- May 8, 2006
- Messages
- 9,703
- Reaction score
- 2,715
- Points
- 1,945
Apologies for what is probably a really obvious question, but does a VM V6 box need both cable and Ethernet connections, or can it work using Ethernet alone? With the loss of some Freeview muxes, I need an alternative to get channels like BBC4HD, but the thought of having yet another thick run of cable either through or round the house, or having yet more holes drilled through my walls is a non-starter with SWMBO. I have Ethernet cabling in place, but checking the V6 box installation guide I suspect that it needs both connections in order to work, rather than just Ethernet. I would ask VM, but I avoid dancing with that devil unless I really have to ...
Cheers, Clem
Cheers, Clem
