V6 video output
RAINS
Apologies in advance if this has been done to death but pending installation of my new GZ2000 can anyone advise if i need to change the resolution settings on the V6 for a 4k TV? If so, to what?
Many thanks
dante01
The V6 should automatically determine your TV's capabilities and should set itself to 2160p. You may want to modify the video output setting though to allow the box to output non UHD channels and content to be output to the TV using their native resolution? If you leave just the 2160p option selected and the other options deselected then everything will be upscaled to 2160p by the V6.Many suggest letting the TV do the scaling as opposed to having the source do it.
The two 2160p options within the setting correspond with 4K UHD output.
The Best Movies and TV Shows Coming to Netflix in November 2020: Tom's Thumbs.
