Is it standard that Vesa mounts are in the dead centre of the TV (vertically)? Just trying to plan a wall mount to be capable of taking a larger size at some stage in the future and clearance above a piece of furniture is critical!
So a typical 50" screen is 651mm tall and a 55 is 722mm. If I assume that the lowest edge of a 55" screen won't be much more than 361mm below centre of mount, am I safe?!
