Just signed up to Virgin after being on Sky Q for years. I have gone for the top bundle so I am getting 2 V6 boxes. I understand they are not a master and slave like Sky Q but 2 full boxes in their own right. Have read a number of differing stories online about the below so hoping you can clear up:
Question is, can the "main" V6 box in the living room be connected via Wifi only? Or does the coax that goes to the router also need to go to the V6 box? Issue is that the entry point for the virgin cable is in the corner of the house where I have my router currently and the tv is in the diagonally opposite corner ...
Similarly for the second V6 box, this will be in an upstairs bedroom so ideally I'd connect this via WiFi only if possible? I definitely don't want a coax run up here.
Its a new build house so WiFi signal is good everywhere.
TIA
TIA
