SaintGermain
Hello,
I have bought a used Visonic Powermax Pro with 3 motion detectors (Visonic Next Plus K9-85 MCW).
To test them I put them all on a shelf and tried to walk around (using the LED as detection indicator).
It seems that one is working correctly, but the others are not triggering, except when I am right in front of them (with my nose almost touching the sensor).
I've tried cleaning the front, waiting a long time before testing and to set the jumper to 1-event detection, but same result.
It doesn't seem to be related to battery level (normally when the battery is too low, I should receive some warning).
Is there something I can do to improve the detection ? Or do I have to buy new ones ?
If yes, they are not as reliable as I thought they will be.
