Cocksure
Does anyone have a wet air source heat pump and if so what are the electricity cost of running one, how long do they take to heat up the radiators, how hot do they get etc.
Basically I know nothing about them but quite fancy fitting one myself to try. So any information/feedback would be helpful. Currently planning on fitting a 14kw Mitsubishi unit if there any good?
Also does anyone know if you can link two units together into one system? It’s 240 square meters so the 14 kw is probably not large enough to do it all and a second unit might well be required if the 1st one works out. I just plan to do so many radiators for now and the remainder of a old gas boiler as needed
