Quantcast
Question Which AV Receiver, Budget Up To £400
Newspapertaxi
Not posted on here for ages but still like to lurk
I'm looking to replace my 8 year old Denon AVR2312 that's now developed a fault but don't want to break the bank as I have pretty basic needs.
My room is 5m by 4m though, because of the way it's set out, you could say it's 5m by 2.5m.
Most of my viewing is via SKY Q (I don't have an external arial) with the occasional blu ray.
TV is an aging Samsung 55" UE8000 which will shortly be upgraded to a new 4K set (probably the Samsung QE55Q80R)
Speakers are 5.1 KEF eggs HT3000 series that are getting on a bit but are too smart to want to replace.
Having a small room I'll be sticking to 5.1
Was looking at the Marantz NR 1510 - is 50W enough to drive my speakers? (I'm assuming it's enough for my small room). Am I paying a premium for it's small size?
Can you recommend anything more suitable for my needs?
Thanks in advance
