Mr Flibble
Established Member
- Joined
- Aug 10, 2009
- Messages
- 66
- Reaction score
- 3
- Points
- 13
My cinema is in a loft room, with sloping roof.
I've currently 5.1, with the FL and FR channels in the corners of the room either side of the screen.
I've always assumed that height channels aren't possible due to the low height of the room, nor wides due to the width.
If angle is actually more important than distance and Audyssey DSX will calibrate the speakers: can I place the wides and height quite a lot closer to the listener?
This will achieve the right angles, but have them half way into the room.
Thanks!
Thanks!
