AMCross
- Joined
- Dec 3, 2003
- Messages
- 6,338
- Reaction score
- 233
- Points
- 1,302
- Age
- 54
- Location
- Livingston,Scotland
anyone else having the same issue
when doing a clean install I can format the hard drive but it wont let me partition it
when I press next it tells me to check log files and then stops install
Iso image on usb stick has been used loads of times with no issue
so in this instance I just rebooted and used a win 7 iso on usb and works fine
hard drive checks out using usual tools
is the win 10 install experience not perfect ?
