Yamaha 209 router change now can find sound bar on iphone
kennycapes
Hi all,
anyone else got a Yam 209 that either disconnected from the router or got a new router and now cant get it to connect over wifi.
I got a new router from sky,
following the setup instructions on the phone,
wifi icon is flashing on my sound bar but the phone just say "no sound bar found",
please help,
cheers
Clem_Dye
You might need to do a factory reset on the 209, to force it through the connection routines again.
kennycapes
Cheers, just done that and now wifi is working,
but then i couldnt get any sound from the TV. Messed about with the TV settings but no joy.
swapped the HDMI cable from TV to sound bar for a different one and its now working,
explain that!!!!!!!!!!!!!!!!!!!!!!!!!
dam modern tech :)
The Best Movies and TV Shows Coming To Netflix in October 2020. Tom's Thumbs.
