My 3067 has developed a fault.
During playback there is a large amount of crackling noise from the rear right channel.
Setup is 5.1, and the source is a Virgin TIVO box in HDMI2 which normally outputs DD2.0. It has also happened with a Blu-Ray into HDMI1, which I think would have been a DD7.1 source. The sound programme will be surround decode.
It doesn't happen all the time, usually after about 10 mins or so, but once it starts it will persist, and needs to receiver putting into standby for a while and then when turned back on it should be back to normal. Sometimes it will run for hours without fault...
Changing the sound programme has no effect, and even by putting it into mute, there will still be the static noise from the right rear (all the desired sound will mute as expected).
Any thoughts,
Steve
