EvertonMonkey
Established Member
- Joined
- Nov 3, 2001
- Messages
- 194
- Reaction score
- 30
- Points
- 67
After years of use without any problems, over the last few weeks my 6 year old Yamaha RX-V2067 receiver has started exhibiting some sound issue when its initially turned on.
So basically when its turned on first thing in the morning, there is either no sound or short burst of sound then silence. More recently sometimes it pops or loud continuous buzz like static. If I turn it off (sometimes a couple of power cycles needed) and back on it usually starts to work again and once its on its fine, but its as if its struggling to pick up the sound / decode the audio. I'm not sure if I'm just imagining this but it also seems like the sound is a little quieter on the normal listening volume
All devices are connected by HDMI and all inputs have the same issue, so its not just one input.
I've been reading online and some of the evidence point towards a capacitor on the way out, but I'm not totally sure or how to test. Anyone had any problems like this in the past or any ideas what it could be / how to fix ?
Any help appreciated
