rosenelson
Established Member
- Joined
- May 4, 2012
- Messages
- 389
- Reaction score
- 19
- Points
- 85
Have music on PC, NAS and iPod/iPhones
Thanks Dante, 2 ch stereo should do. Would I feed these input to irdac and irdacs output to where in 673 please?
The time lag / lip sync delay issue is doing my head in and it's really spoiling our enjoyment of incredible picture quality. I've used the time delay feature that the Samsung has built in but it goes from being really obvious to really, really, really obvious. It's not just out, it's massively out.
Is the sound ahead of the picture?
If so you set the lipsync delay through the Yamaha menus
I figured out this amp has the 4K pass through but does anyone know if it accepts the 4K HDR pass through as I'm upgrading to a 4K Blu Ray player
I used to run everything through the receiver directly(hdmi in, then one out to tv) but since moving to 4K this obviously had to change. Now I'm having to use an optical out on the tv to the receiver. The problem I'm running into is the lip sync. I have tried auto and manual and can't get it right. No problem with regular blu Rays or streamed content, only with 4K blu Rays. Any advice?The RXV673 cannot convey UHD encoded content, lacks HDCP 2.2 compliance and has no ability to handle or passthrough HDR metadata. You'd need at least a late version 2.0 HDMI chipset to give you any of these abilities and preferably an implementation of HDMI version 2.0a. The RXV673 has HDMI version 1.4 which cannot be updated to give it the capabilities needed for UHD or HDR compliance. The ability to passthrough content with a 4K resolution should not be confused with the abilities a receiver needs for it to be able to handle and passthrough UHD encoded content.
Hello! Hoping someone can point me in the right direction......
I have a blu-ray player connected to this amp via HDMI (for video) and optical (for audio). However, I want to do away with the optical cable - it is my understanding that this amp will accept a Dolby Digital signal over HDMI but I can't get it to work at all - just goes into pro-logic / PCM mode and any amount of playing with settings doesnt seem to sort the issue. Any assistance would be much appreciated!!
Hi - are there any updates that will allow 4k pass through? Or do i need to buy a new receiver?
thanks ill try when i get homedid you changed the settings to pass through
press on screen
setup (scroll down)
video (left)
video mode (enter)
choose direct
dont think so
i passed through Sky Q to a UHD tv and it didnt detect a UHD source?
