mattkhan
the rolloff is *really* steep, if this is the amp then there is no way that is a natural rolloff
personally I would not lash out 00s on amps until I knew it really was the amp but then I have a bunch of random amps in the house already so maybe you have to buy an amp in order to find that out
do you have another amp handy? any old thing will do as you don't need much power. Some cheap class AB thing is fine, just something that will typically have wide bandwidth. If you do then measure it powering the subs and compare the response. You may need to reduce the level of course to not stress the amp (depending on what it is).
I guess wiring might be a challenge mind you but then you'll need to solve that anyway if you do get some inukes in
