Yes you can at least on the Z1000 Pro, select Settings, Other, down to Front Display Panel Setting, select Brightness and select Close.One short question, can you turn off the frontpanel ?
No, currently it has a lot of bugs and issues related with DV, HEVC 1080p files, date/time sync...Hi all. Simple question... Is that box able to playback DV from UHD ISO? I have Z9s and I don't know is there a point to upgrade to Z9x....
if by "good support" you mean no answer. Then, yes, they are providing good support.To be fair the Zidoo forums are the place to go for these 3 (Z9x, Z10 Pro and Z1000 Pro) new players. Because of the new SOC, the firmwares are still in development and Zidoo are providing good support. So I suggest you look over there for comprehensive answers to your above questions quite a few very experienced users answering a plethora of questions on a daily (almost hourly) basis.
I would like to know this to. Is it easy to shift the subtitles up and down?Do these players have any features to support a 2:35 scope screen setup, which uses PJ zoom.
eg
movie wall tiles displayed in 2.35:1 format rather than 16:9
OSD displayed within 235 area, not within black bars
i think I saw it can reposition subtitles, however it would also need to move the OSD for playback info plus adjust the menus and video wall format else you can’t see them in a normal scope situation.I would like to know this to. Is it easy to shift the subtitles up and down?
Moving subtitles on the Z1000 Pro is done by playing the file press your Menu button select subtitle and then subtitle options and you can select move from there.I would like to know this to. Is it easy to shift the subtitles up and down?
So, is picture quality better on the z9x vs the z9s?
Sounds good. Does that apply to projector owners, or only those with DV compatible TVs? i.e. are there improvements to1080p and non-DV 4k content, its not just the inclusion of DV?
How do these compare to the Zappiti?
And do you see the result of the shift while you are shifting?Moving subtitles on the Z1000 Pro is done by playing the file press your Menu button select subtitle and then subtitle options and you can select move from there.
Yes you do, you can also change text size and colour.And do you see the result of the shift while you are shifting?
